Bundle Adjustment Constrained Smoothing for Multi-view Point Cloud Data
Direct use of denoising and mesh reconstruction algorithms on point clouds originating from multi-view images is often oblivious to the reprojection error. This can be a severe limitation in applications which require accurate point tracking, e.g., metrology. In this paper, we propose a method for improving the quality of such data without forfeiting the original matches. We formulate the problem as a robust smoothness cost function constrained by a bounded reprojection error. The arising optimization problem is addressed as a sequence of unconstrained optimization problems by virtue of the barrier method. Substantiated experiments on synthetic and acquired data compare our approach to alternative techniques.
