The graphical modeling as a support tool for planning and monitoring sustainable construction projects and public infrastructure
Visual communication through graphical scheduling methods is often the point of failure for the planning and monitoring of construction projects. The proposed chronographic model studies the graphical visual representation of the schedule in the spatial dimension. This model classifies the scheduling entities, especially the activities, the resources and the area of work, into three types of entities. These entity types symbolize the construction operations, establish the relationships between them, and determine the direction of flow of information. Using these entities, the planner can define the graphical approach in order to display the schedule information under diverse, compatible layouts and switch between these layouts. The primary goal is for all stakeholders to have a better understanding of the scheduling logic. This paper describes the meta-model that is used to structure these entities into classes, define their classification criteria with the visual representation of the scheduling approaches, and infer the relationships amongst them. The use of the Entity Relationship (ER) model to create the meta-model ensures uniqueness and stability. The result is the development and implementation of a meta-model that allows the planner to display the schedule information's under diverse approaches, add/edit entities, organize them into classes and infer their behavior towards each other in order to gain a better understanding of their roles. The validation process is done through the generation of the ER conceptual data model, adapted to the Chronographic construction scheduling approach that embraces change while maintaining consistency and self-validation despite the addition of new entities in classes.
La communication visuelle par des méthodes de planification graphiques est souvent le point d'échec pour la planification et le contrôle de projets de construction. Le modèle de "chronographique" proposé étudie la représentation visuelle graphique du planning dans l'espace. Ce modèle classifie les entités de planification, particulièrement les activités, les ressources et la zone de travail, dans trois types d'entités. Ces types d'entité symbolisent les opérations de construction, établissent les relations entre elles et déterminent la direction des flux d'informations. En utilisant ces entités, le planificateur peut définir l'approche graphique pour afficher les informations du planning sous des représentations diverses, compatibles et même passer d'une représentation à une autre. Le but principal pour toutes les parties prenantes est d'obtenir une meilleure compréhension de la logique de planification. Cet article décrit le meta-modèle qui est utilisé pour structurer ces entités dans des classes, définir leurs critères de classification avec la représentation visuelle des approches de planification et déduire les relations entre elles. L'utilisation du modèle Entité-Relation (ER) pour créer le meta-modèle, assure l'unicité et la stabilité de cette structure. Le résultat est la mise en œuvre d'un meta-modèle et le développement d'un logiciel qui permet au planificateur d'afficher les informations du planning dans des approches diverses, ajouter/éditer des entités, les organiser dans des classes et déduire leur comportement des unes par rapport aux autres pour obtenir une meilleure compréhension de leurs rôles. Le processus de validation est fait par la génération du modèle conceptuel de données, modèle adapté à la méthode chronographique de construction de planning qui associe la possibilité de changement tout en entretenan la cohérence des informations et l'auto-validation malgré l'ajout de nouvelles entités.
