Situation assessment: an end-to-end process for the detection of objects of interest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Aerospace and Electronic Systems Année : 2013
In this article, semi-automatic approaches are developed for wide area situation assessment in near-real-time. The two-step method consists of two granularity levels. The first entity assessment uses a new multi-target tracking algorithm (hybridization of GM-CPHD filter and MHT with road constraints) on GMTI data. The situation is then assessed by detecting objects of interest such as convoys with other data types (SAR, video). These detections are based on Bayesian networks and their credibilistic counterpart.
IEEE_AES_situation.pdf (4.89 Mo) Télécharger le fichier
hal-00763715 , version 1 (11-12-2012)
hal-00763715 , version 2 (08-01-2014)
Evangeline Pollard, Michèle Rombaut, Benjamin Pannetier. Situation assessment: an end-to-end process for the detection of objects of interest. IEEE Transactions on Aerospace and Electronic Systems, 2013, 49 (4), pp.2195-2210. ⟨10.1109/TAES.2013.6621810⟩. ⟨hal-00763715v2⟩
295 Consultations
704 Téléchargements
