Other publications
SIPE: Small Integer Plus Exponent
Vincent Lefèvre 1
1 ARIC - Arithmetic and Computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : SIPE (Small Integer Plus Exponent) is a mini-library in the form of a C header file, to perform computations in very low precisions with correct rounding to nearest in radix 2. The goal of such a tool is to do proofs of algorithms/properties or computations of tight error bounds in these precisions by exhaustive tests, in order to try to generalize them to higher precisions. The currently supported operations are the addition, the subtraction, the multiplication, the FMA, and miscellaneous comparisons and conversions. Timing comparisons have been done with hardware IEEE-754 floating point and with GNU MPFR.
Complete list of metadatas
https://hal.inria.fr/hal-00763954
Contributor : Vincent Lefèvre <>
Submitted on : Wednesday, December 12, 2012 - 2:03:49 AM
Last modification on : Friday, April 20, 2018 - 3:44:26 PM
Document(s) archivé(s) le : Wednesday, March 13, 2013 - 3:52:00 AM
Identifiers
  • HAL Id : hal-00763954, version 1
Citation
Vincent Lefèvre. SIPE: Small Integer Plus Exponent. 2012. ⟨hal-00763954v1⟩
Share
Metrics
Record views
29
Files downloads
66
