Optimal Anycast Technique for Delay- Sensitive Energy-Constrained Asynchronous Sensor Networks, IN- FOCOM 2009. The 28th Conference on Computer Communications, 2009. ,
Tunable Locally-Optimal Geographical Forwarding in Wireless Sensor Networks With Sleep-Wake Cycling Nodes, 2010 Proceedings IEEE INFOCOM, 2010. ,
DOI : 10.1109/INFCOM.2010.5461956
An Analysis of Stochastic Shortest Path Problems, Mathematics of Operations Research, vol.16, issue.3, 1991. ,
DOI : 10.1287/moor.16.3.580
Relay Selection for Geographical Forwarding in Sleep-Wake Cycling Wireless Sensor Networks, IEEE Transactions on Mobile Computing, vol.12, issue.3 ,
DOI : 10.1109/TMC.2011.279
Distributed Opportunistic Scheduling With Two-Level Probing, IEEE/ACM Transactions on Networking, vol.18, issue.5, 2010. ,
DOI : 10.1109/TNET.2010.2042610
Stochastic Models and Optimal Policy for Selling an Asset, 1962. ,
Optimal Relay Selection with Channel Probing in Wireless Sensor Networks, Dept. of E.C.E, 2011. ,
A survey on routing protocols for wireless sensor networks, Ad Hoc Networks, pp.325-349, 2005. ,
DOI : 10.1016/j.adhoc.2003.09.010
Geographic random forwarding (geraf) for ad hoc and sensor networks: multihop performance, IEEE Transactions on Mobile Computing, vol.2, issue.4, pp.337-348, 2003. ,
DOI : 10.1109/TMC.2003.1255648
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.91.6380
Performance of energy-aware and link-adaptive routing metrics for ultra wideband sensor networks, Mobile Networks and Applications, vol.11, issue.4, pp.509-519, 2006. ,
DOI : 10.1007/s11036-006-7197-y
Optimal joint probing and transmission strategy for maximizing throughput in wireless systems, IEEE Journal on Selected Areas in Communications, vol.26, issue.8, pp.1546-1555, 2008. ,
DOI : 10.1109/JSAC.2008.081020
Optimal Stopping and Applications Available: http://www.math.ucla, Contents.html [13] D. P. Bertsekas, Dynamic Programming and Optimal Control, 2005. ,
An optimal stopping problem with two levels of incomplete information, Mathematical Methods of Operations Research, vol.23, issue.1, pp.119-131, 1997. ,
DOI : 10.1007/BF01194251
Comparison Methods for Queues and other Stochastic Models, 1983. ,
