LES investigation of the flow through an effusion-cooled aeronautical combustor model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Flow, Turbulence and Combustion Année : 2012
The present study is devoted to the analysis of the behaviour of the flow through an effusion-cooled aeronautical combustor model. High-fidelity calculations are performed on an experimental model of a combustion chamber multi-perforated wall and compared to experimental measurements. The effect of combustion instability on the effusion-cooling system is investigated by studying the interaction of an acoustic wave with the jets-in-crossflow issued from the cooling plate. It is shown that the mass-flow rate through the plate can be drastically reduced by the acoustic wave, which demonstrates the destructive effect that such instability may have on the cooling of an aeronautical combustion chamber.
hal-00764269 , version 1 (12-12-2012)
Emmanuel Motheau, Thomas Lederlin, Juan-Luis Florenciano, Pascal Bruel. LES investigation of the flow through an effusion-cooled aeronautical combustor model. Flow, Turbulence and Combustion, 2012, 88 (1-2), pp.169-189. ⟨10.1007/s10494-011-9357-9⟩. ⟨hal-00764269⟩
146 Consultations
0 Téléchargements
