Scaling-up Knowledge for a Cognizant Robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thomas Degris
  • Fonction : Auteur
  • PersonId : 934007
Joseph Modayil
  • Fonction : Auteur
This paper takes a new approach to the old adage that knowl- edge is the key for artificial intelligence. A cognizant robot is a robot with a deep and immediately accessible understand- ing of its interaction with the environment--an understand- ing the robot can use to flexibly adapt to novel situations. Such a robot will need a vast amount of situated, revisable, and expressive knowledge to display flexible intelligent be- haviors. Instead of relying on human-provided knowledge, we propose that an arbitrary robot can autonomously acquire pertinent knowledge directly from everyday interaction with the environment. We show how existing ideas in reinforce- ment learning can enable a robot to maintain and improve its knowledge. The robot performs a continual learning process that scales-up knowledge acquisition to cover a large number of facts, skills and predictions. This knowledge has seman- tics that are grounded in sensorimotor experience. We see the approach of developing more cognizant robots as a necessary key step towards broadly competent robots.
Degris-modayil-AAAI-Symposium-2012.pdf (322.95 Ko) Télécharger le fichier
hal-00764289 , version 1 (12-12-2012)
  • HAL Id : hal-00764289 , version 1
Thomas Degris, Joseph Modayil. Scaling-up Knowledge for a Cognizant Robot. AAAI Spring Symposium on Designing Intelligent Robots: Reintegrating AI., Mar 2012, Stanford, United States. ⟨hal-00764289⟩
115 Consultations
63 Téléchargements
