Using Salomé to reproduce the structure and to observe the diffusion of water molecules in biological tissue - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Diffusion magnetic resonance imaging (DMRI) can give useful information on cellular structure and its structural changes. Salomé is used to reproduce some complicated shapes in d-dimensions (d=2,3) that are used to represent the natural structures of various biological tissue. The meshes representing these shapes are used as inputs to a finite element code that we built upon FENICS C++. Results were obtained for a model of globlastoma (cerebral tumor) as a Voronoi diagram which was used to observe the convergence of the apparent diffusion tensor in long-time limit to the effective diffusion tensor computed by homogenization theory.
Poster_for_SalomA_Day.pdf (2.12 Mo) Télécharger le fichier
hal-00764328 , version 1 (12-12-2012)
  • HAL Id : hal-00764328 , version 1
Dang Van Nguyen, Denis S Grebenkov, Jing-Rebecca Li. Using Salomé to reproduce the structure and to observe the diffusion of water molecules in biological tissue. 2012. ⟨hal-00764328⟩
452 Consultations
80 Téléchargements
