Uniform strong consistency of a frontier estimator using kernel regression on high order moments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Probability and Statistics Année : 2014
We consider the high order moments estimator of the frontier of a random pair introduced by Girard, S., Guillou, A., Stupfler, G. (2012). Frontier estimation with kernel regression on high order moments. In the present paper, we show that this estimator is strongly uniformly consistent on compact sets and its rate of convergence is given when the conditional cumulative distribution function belongs to the Hall class of distribution functions.
Frontier_beta_final.pdf (256.15 Ko) Télécharger le fichier
hal-00764425 , version 1 (13-12-2012)
hal-00764425 , version 2 (16-07-2013)
Stéphane Girard, Armelle Guillou, Gilles Stupfler. Uniform strong consistency of a frontier estimator using kernel regression on high order moments. ESAIM: Probability and Statistics, 2014, 18, pp.642--666. ⟨10.1051/ps/2013050⟩. ⟨hal-00764425v2⟩
462 Consultations
183 Téléchargements
