The Improbability That an Elliptic Curve Has Subexponential Discrete Log Problem under the Menezes???Okamoto???Vanstone Algorithm, Journal of Cryptology, vol.11, issue.2, pp.141-145, 1998. ,
DOI : 10.1007/s001459900040
Computing Hilbert Class Polynomials, Algorithmic Number Theory ? ANTS-VIII, pp.282-295, 2008. ,
DOI : 10.1007/978-3-540-79456-1_19
URL : https://hal.archives-ouvertes.fr/inria-00246115
Minimizing the use of random oracles in authenticated encryption schemes, Information and Communications Security, pp.1-16, 1997. ,
DOI : 10.1007/BFb0028457
Elliptic curves in cryptography Lecture Note Series, 2000. ,
Advances in Elliptic Curve Cryptography, 2005. ,
DOI : 10.1017/CBO9780511546570
Evaluating 2-DNF Formulas on Ciphertexts, Theory of Cryptography ? TCC 2005, pp.325-341, 2005. ,
DOI : 10.1007/978-3-540-30576-7_18
Fast algorithms for computing isogenies between elliptic curves, Mathematics of Computation, vol.77, issue.263, pp.1755-1778, 2008. ,
DOI : 10.1090/S0025-5718-08-02066-8
URL : https://hal.archives-ouvertes.fr/inria-00091441
Elliptic Curves Suitable for Pairing Based Cryptography, Designs, Codes and Cryptography, vol.2248, issue.5, pp.133-141, 2005. ,
DOI : 10.1007/s10623-004-3808-4
Generic groups, collision resistance, and ECDSA. Designs, Codes and Cryptography, pp.119-152, 2005. ,
Bekanntmachung zur elektronischen Signatur nach dem Signaturgesetz und der Signaturverordnung ( ¨ UbersichtüberUbersicht¨Ubersichtüber geeignete Algorithmen), Bundesanzeiger, vol.85, 2011. ,
On cryptographic protocols employing asymmetric pairings ??? The role of <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd"><mml:mi>??</mml:mi></mml:math> revisited, Discrete Applied Mathematics, vol.159, issue.13, pp.1311-1322, 2011. ,
DOI : 10.1016/j.dam.2011.04.021
A Course in Computational Algebraic Number Theory, Graduate Texts in Mathematics, vol.138, 1993. ,
DOI : 10.1007/978-3-662-02945-9
Action of Modular Correspondences around CM Points, Algorithmic Number Theory ? ANTS-V, volume 2369 of Lecture Notes in Computer Science, pp.234-243, 2002. ,
DOI : 10.1007/3-540-45455-1_19
The geometry of flex tangents to a cubic curve and its parameterizations, Journal of Symbolic Computation, vol.47, issue.3, pp.266-281, 2012. ,
DOI : 10.1016/j.jsc.2011.11.003
URL : https://hal.archives-ouvertes.fr/hal-01104612
The GHS attack in odd characteristic, Journal of the Ramanujan Mathematical Society, vol.18, issue.1, pp.1-32, 2003. ,
Elliptic and modular curves over finite fields and related computational issues, Computational perspectives on number theory, pp.21-76, 1995. ,
The complexity of class polynomial computation via floating point approximations, Mathematics of Computation, vol.78, issue.266, pp.1089-1107, 2009. ,
DOI : 10.1090/S0025-5718-08-02200-X
URL : https://hal.archives-ouvertes.fr/inria-00001040
Computing modular polynomials in quasi-linear time, Mathematics of Computation, vol.78, issue.267, pp.1809-1824, 2009. ,
DOI : 10.1090/S0025-5718-09-02199-1
URL : https://hal.archives-ouvertes.fr/inria-00143084
Hashing into Hessian curves, 2011. ,
DOI : 10.1504/ijact.2014.062737
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.400.7529
Converting pairing-based cryptosystems from compositeorder groups to prime-order groups, Advances in Cryptology ? EUROCRYPT 2010, pp.44-61, 2010. ,
A Taxonomy of Pairing-Friendly Elliptic Curves, Journal of Cryptology, vol.2, issue.5, pp.224-280, 2010. ,
DOI : 10.1007/s00145-009-9048-z
A remark concerning m-divisibility and the discrete logarithm problem in the divisor class group of curves, Math. Comp, vol.62, pp.865-874, 1994. ,
Applications of arithmetical geometry to cryptographic constructions Finite Fields and Applications ? Proceedings of The Fifth International Conference on Finite Fields and Applications F q 5, pp.128-161, 1999. ,
IKE and IKEv2 authentication using the elliptic curve digital signature algorithm (ECDSA) RFC 4754, Internet Engineering Task Force, 2007. ,
Extending the GHS Weil Descent Attack, Advances in Cryptology ? EUROCRYPT 2002, pp.29-44, 2002. ,
DOI : 10.1007/3-540-46035-7_3
Pairing-Based Cryptography ? Pairing, Lecture Notes in Computer Science, vol.5209, 2008. ,
A cryptographic application of Weil descent, Cryptography and Coding, pp.191-200, 1999. ,
Improving the parallelized Pollard lambda search on anomalous binary curves, Mathematics of Computation, vol.69, issue.232, pp.1699-1705, 2000. ,
DOI : 10.1090/S0025-5718-99-01119-9
Constructive and destructive facets of Weil descent on elliptic curves, Journal of Cryptology, vol.44, issue.1, pp.19-46, 2002. ,
DOI : 10.1007/s00145-001-0011-x
URL : https://hal.archives-ouvertes.fr/inria-00512763
Fast algorithms for computing the eigenvalue in the Schoof-Elkies-Atkin algorithm, Proceedings of the 2006 international symposium on Symbolic and algebraic computation , ISSAC '06, pp.109-115, 2006. ,
DOI : 10.1145/1145768.1145791
URL : https://hal.archives-ouvertes.fr/inria-00001009
Index calculus for abelian varieties of small dimension and the elliptic curve discrete logarithm problem, Journal of Symbolic Computation, vol.44, issue.12, pp.1690-1702, 2009. ,
DOI : 10.1016/j.jsc.2008.08.005
URL : https://hal.archives-ouvertes.fr/inria-00337631
Bluekrypt cryptographic key length recommendation, 2011. ,
Asymptotically optimal p-adic point-counting Posting to the Number Theory List, 2002. ,
Kedlaya's Algorithm in Larger Characteristic, International Mathematics Research Notices, vol.29, issue.22, 2007. ,
DOI : 10.1093/imrn/rnm095
Pairing Lattices, Lecture Notes in Computer Science, vol.5209, pp.18-38, 2008. ,
DOI : 10.1007/978-3-540-85538-5_2
The Eta Pairing Revisited, IEEE Transactions on Information Theory, vol.52, issue.10, pp.4595-4602, 2006. ,
DOI : 10.1109/TIT.2006.881709
How to Hash into Elliptic Curves, Lecture Notes in Computer Science, vol.5677, pp.303-316, 2009. ,
DOI : 10.1007/978-3-642-03356-8_18
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.215.5920
Cover and decomposition index calculus on elliptic curves made practical ? Application to a seemingly secure curve over F p 6, 2011. ,
Pairing-Based Cryptography ? Pairing, Lecture Notes in Computer Science, vol.6487, 2010. ,
Encoding Points on Hyperelliptic Curves over Finite Fields in Deterministic Polynomial Time, Lecture Notes in Computer Science, vol.6487, pp.278-297, 2010. ,
DOI : 10.1007/978-3-642-17455-1_18
URL : https://hal.archives-ouvertes.fr/hal-00694136
Elliptic curve cryptosystems, Mathematics of Computation, vol.48, issue.177, pp.203-209, 1987. ,
DOI : 10.1090/S0025-5718-1987-0866109-5
Selecting cryptographic key sizes (extended abstract), Public Key Cryptography ? 3rd International Workshop on Practice and Theory in Public Key Cryptosystems PKC 2000, pp.446-465, 2000. ,
Counting Points on Elliptic Curves over Finite Fields of Small Characteristic in Quasi Quadratic Time, Advances in Cryptology ? EUROCRYPT 2003, pp.360-373, 2003. ,
DOI : 10.1007/3-540-39200-9_22
URL : https://hal.archives-ouvertes.fr/hal-01102038
Reducing elliptic curve logarithms to logarithms in a finite field, IEEE Transactions on Information Theory, vol.39, issue.5, pp.1639-1646, 1993. ,
DOI : 10.1109/18.259647
Handbook of applied cryptography, Series on Discrete Mathematics and its Applications, 1997. ,
DOI : 10.1201/9781439821916
Lettre adresséè a Gaudry et Harley, 2000. ,
Computing the eigenvalue in the Schoof? Elkies?Atkin algorithm using abelian lifts, Proceedings of the 2007 International Symposium on Symbolic and Algebraic Computation ? IS- SAC 2007, pp.285-292, 2007. ,
Use of elliptic curves in cryptography Advances in Cryptology ? CRYPTO '85, Lecture Notes in Computer Science, vol.218, pp.417-426, 1986. ,
Handbook of Finite Fields, Discrete Mathematics and Its Applications. Chapman and Hall/CRC, Boca Raton, 2013. ,
A Note on Elliptic Curves Over Finite Fields, Mathematics of Computation, vol.49, issue.179, pp.301-304, 1987. ,
DOI : 10.2307/2008268
The canonical lift of an ordinary elliptic curve over a finite field and its point counting, J. Ramanujan Math. Soc, vol.15, issue.4, pp.247-270, 2000. ,
Fermat quotients and the polynomial time discrete log algorithm for anomalous elliptic curves, Comment. Math. Univ. St. Paul, vol.47, issue.1, pp.81-92, 1998. ,
Elliptic curves over finite fields and the computation of square roots mod p, Mathematics of Computation, vol.44, issue.170, 1985. ,
Evaluation of discrete logarithms in a group of $p$-torsion points of an elliptic curve in characteristic $p$, Mathematics of Computation of the American Mathematical Society, vol.67, issue.221, pp.353-356, 1998. ,
DOI : 10.1090/S0025-5718-98-00887-4
Pairing-Based Cryptography ? Pairing, Lecture Notes in Computer Science, vol.5671, 2009. ,
Construction of Rational Points on Elliptic Curves over Finite Fields, Algorithmic Number Theory ? ANTS-VII, pp.510-524, 2006. ,
DOI : 10.1007/11792086_36
Points on elliptic curves over finite fields, Acta Arithmetica, vol.117, issue.3, pp.293-301, 2005. ,
DOI : 10.4064/aa117-3-7
The Discrete Logarithm Problem on Elliptic Curves of Trace One, Journal of Cryptology, vol.12, issue.3, pp.193-196, 1999. ,
DOI : 10.1007/s001459900052
The Exact Security of ECIES in the Generic Group Model, Cryptography and Coding, pp.73-84, 2001. ,
DOI : 10.1007/3-540-45325-3_8
ECRYPT II yearly report on algorithms and keysizes, European Network of Excellence in Cryptology II, 2009. ,
Flaws in Applying Proof Methodologies to Signature Schemes, Advances in Cryptology ? CRYPTO 2002, pp.93-110, 2002. ,
DOI : 10.1007/3-540-45708-9_7
Genus 1 point counting in essentially quartic time and quadratic space, Slides, 2010. ,
Genus 1 point-counting record modulo a 5000+ digit prime, 2010. ,
Pairing-Based Cryptography ? Pairing, Lecture Notes in Computer Science, vol.4575, 2007. ,
BemerkungüberBemerkung¨Bemerkungüber die Auflösung quadratischer Congruenzen Nachrichten von der Königl. Gesellschaft der Wissenschaften und der Georg- Augusts, pp.344-346, 1891. ,
Optimal Pairings, IEEE Transactions on Information Theory, vol.56, issue.1, pp.455-461, 2010. ,
DOI : 10.1109/TIT.2009.2034881
Evidence that XTR is more secure than supersingular elliptic curve cryptosystems, Journal of Cryptology, vol.17, issue.4, pp.277-296, 2004. ,
DOI : 10.1007/3-540-44987-6_13
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.100.7702
Abelian varieties over finite fields, Annales Scientifiques de l' ´ Ecole Normale Supérieure, 4 e Série, pp.521-560, 1969. ,
Faster attacks on elliptic curve cryptosystems, Selected Areas in Cryptography ? SAC '98, pp.190-100, 1999. ,
