Graph traversal techniques and the maximum flow problem in distributed computing, IEEE Trans. on SE, SE, vol.9, issue.4, pp.504-512, 1983. ,
Clock synchronization in the presence of omission and performance faults, and processors joins, Proc. of 16th IEEE Symposium on FaultTolerant Computing Systems, pp.218-223, 1986. ,
On the possibility and impossibility of achieving clock synchronization, Proc. of 16th ACM Symposium on Theory of Computing, pp.504-511, 1984. ,
Estimating global time in distributed system, Proc. 7th Int. Conf. on Distributed Computing Systems, 1987. ,
Dissemination of system time, IEEE Transactions on Communications, COM, vol.21, issue.5, pp.605-623, 1973. ,
A network time controler for a distributed berkeley UNIX system, IEEE Distr. Proc. Tech. Comm. Newsletter, SI, vol.2, issue.6, pp.7-15, 1984. ,
Performance dans les systèmes répartis: des outils pour les mesures, 1988. ,
Fault-tolerant clock synchronization, Proc. of the Third ACM Symposium on Principles of Distributed Computing, pp.89-102, 1984. ,
A multi-processor Estelle to C compiler to experiment distributed algorithms on parallel machines, Proc. of the 9 th IFIP International Workshop on Protocol Specification, Testing, and Verification, 1989. ,
URL : https://hal.archives-ouvertes.fr/hal-00765072
Accuracy of time measurement in distributed real time systems, 5th Symposium on Reliability in Distributed Software and Database Systems, pp.35-41, 1986. ,
Clock synchronization in distributed real time systems, In IEEE Transaction on Computers, Special issue on Real Time Systems, pp.933-940, 1987. ,
Synchronization and fault-masking in redundant real time systems, Proc. of the FTCS 14, pp.151-157, 1984. ,
Time, clocks and the ordering of events in a distributed system, Communications. of the ACM, vol.21, pp.558-565, 1978. ,
Synchronizing clocks in the presence of faults, Journal of the ACM, vol.32, issue.1, pp.52-78, 1985. ,
A new fault-tolerant algorithm for clock synchronization, Proc. of the Third ACM Symposium on Principles of Distributed Computing, pp.75-88, 1984. ,
Maintaining time in a distributed system, In ACM Operating Systems Rev, pp.44-54, 1983. ,
A paradigm for reliable clock synchronization, Proc, pp.85-104, 1986. ,
An Overview of Clock Synchronization, 1988. ,
Optimal clock synchronization, 4th Annual ACM Symposium on Principles of Distributed Computing, pp.71-86, 1985. ,
DOI : 10.1145/323596.323603
URL : http://www.cs.cornell.edu/Courses/cs614/2003SP/papers/ST87.pdf
