Scheduling multithreaded computations by work stealing, Journal of the ACM, vol.46, issue.5, pp.720-748, 1999. ,
DOI : 10.1145/324133.324234
Parallel Branch and Bound on a CPU-GPU System, 2012 20th Euromicro International Conference on Parallel, Distributed and Network-based Processing, pp.392-398, 2012. ,
DOI : 10.1109/PDP.2012.23
URL : https://hal.archives-ouvertes.fr/hal-01152948
A New Parallel Schema for Branch-and-Bound Algorithms Using GPGPU, 2011 23rd International Symposium on Computer Architecture and High Performance Computing, pp.41-47, 2011. ,
DOI : 10.1109/SBAC-PAD.2011.20
An Adaptative Multi-GPU Based Branch-and-Bound. A Case Study: The Flow-Shop Scheduling Problem, 2012 IEEE 14th International Conference on High Performance Computing and Communication & 2012 IEEE 9th International Conference on Embedded Software and Systems, 2012. ,
DOI : 10.1109/HPCC.2012.59
URL : https://hal.archives-ouvertes.fr/hal-00705868
Derivation of a termination detection algorithm for distributed computations. Control Flow and Data Flow: concepts of distributed programming, pp.507-512, 1987. ,
A message passing benchmark for unbalanced applications. Simulation Modelling Practice and Theory, pp.1177-1189, 2008. ,
The implementation of the cilk-5 multithreaded language, SIGPLAN Not, vol.33, pp.212-223, 1998. ,
Scalable work stealing, ACM Conf. on High Performance Computing Networking, Storage and Analysis, pp.1-5311, 2009. ,
GPU Implementation of the Branch and Bound Method for Knapsack Problems, 2012 IEEE 26th International Parallel and Distributed Processing Symposium Workshops & PhD Forum, pp.1769-1777, 2012. ,
DOI : 10.1109/IPDPSW.2012.219
URL : https://hal.archives-ouvertes.fr/hal-01149777
A GPU-accelerated b&b algorithm for the flow-shop scheduling problem, 14 th IEEE Conf. on Cluster Computing, 2012. ,
Hierarchical work stealing on manycore clusters, 5 th Conf. on Partitioned Global Address Space Prog. Models, 2011. ,
Lifeline-based global load balancing, 16 th ACM Symp. on Principles and practice of parallel programming (PPoPP '11), pp.201-212, 2011. ,
Benchmarks for basic scheduling problems, European Journal of Operational Research, vol.64, issue.2, pp.278-285, 1993. ,
DOI : 10.1016/0377-2217(93)90182-M
