Estimation of Probabilistic Minimum Inter-arrival Times Using Extreme Value Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Adriana Gogonel
Dorin Maxim
  • Fonction : Auteur
  • PersonId : 884508
Liliana Cucu
  • Fonction : Auteur
  • PersonId : 844766
Verifying timing constraints is the main purpose of analyses for real-time systems. This verification can be done using probabilistic methods, which rely on statistical estimations of certain task parameters. In this paper, we address the problem of determining probability distributions for minimum inter-arrival times of tasks, using statistical methods applied on data obtained through measurements.
JW_2012_submited_26september_v2.pdf (261.42 Ko) Télécharger le fichier
hal-00766063 , version 1 (24-01-2013)
  • HAL Id : hal-00766063 , version 1
Cristian Maxim, Adriana Gogonel, Dorin Maxim, Liliana Cucu. Estimation of Probabilistic Minimum Inter-arrival Times Using Extreme Value Theory. 2013. ⟨hal-00766063⟩
212 Consultations
515 Téléchargements
