Comparing workflow specification languages: A matter of views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Database Systems Année : 2012
We address the problem of comparing the expressiveness of workflow specification formalisms using a notion of view of a workflow. Views allow to compare widely different workflow systems by mapping them to a common representation capturing the observables relevant to the comparison. Using this framework, we compare the expressiveness of several workflow specification mechanisms, including automata, temporal constraints, and pre-and post-conditions, with XML and relational databases as underlying data models. One surprising result shows the considerable power of static constraints to simulate apparently much richer workflow control mechanisms.
Mots clés
final.pdf (519.18 Ko) Télécharger le fichier
hal-00766210 , version 1 (17-12-2012)
Serge Abiteboul, Pierre Bourhis, Victor Vianu. Comparing workflow specification languages: A matter of views. ACM Transactions on Database Systems, 2012, 37 (10), ⟨10.1145/2188349.2188352⟩. ⟨hal-00766210⟩
101 Consultations
223 Téléchargements
