Computation of plate eigenmodes with the plane wave decomposition method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We develop a practical method for determining the modal frequencies and eigenmodes of a vibrating uniform thin plate, with arbitrary shape and boundary conditions, and uniform in-plane tension. The method is based on the decomposition of the modes as sum of propagative and exponential plane waves. This approach is validated for a circular plate and an odd-shaped plate, where results are shown to match classical results of plate theory, and are shown to require less resources than other numerical schemes.
Fichier non déposé
hal-00766964 , version 1 (19-12-2012)
  • HAL Id : hal-00766964 , version 1
G. Chardon, L. Daudet. Computation of plate eigenmodes with the plane wave decomposition method. WAVES 2011 - The 10th International Conference on Mathematical and Numerical Aspects of Waves, 2011, Vancouver, Canada. ⟨hal-00766964⟩
126 Consultations
0 Téléchargements
