A fast variational framework for accurate solid-fluid coupling, Proceedings of ACM SIGGRAPH 2007, 2007. ,
Real-time simulation and rendering of 3d fluids de GPU Gems, p.30, 2007. ,
Animation and rendering of complex water surfaces, Proceedings of the 29th SIGGRAPH, pp.736-744, 2002. ,
A Hybrid Fluid Simulation On The Graphics Processing Unit (GPU) Master's thesis, 2008. ,
Visual simulation of smoke, Proceedings of ACM SIGGRAPH, pp.15-22, 2001. ,
Simple and Fast Fluids, p.3, 2011. ,
Interactive sph simulation and rendering on the gpu, Proceeding of Eurographics/ACM SIGGRAPH Symposium on Computer Animation 2010, pp.55-64, 2010. ,
Simulation of cloud dynamics on graphics hardware, Proceedings of the SIG- GRAPH/Eurographics Workshop on Graphics Hardware, 2003. ,
A game developer's wish list for researchers, Talk given at the 2011 ACM SIGGRAPH Symposium on Interactive 3D Graphics and Games, 2011. ,
Smoothed particle hydrodynamics on gpus, Proceedings of Computer Graphics International, pp.63-70, 2007. ,
Numerical Calculation of Time-Dependent Viscous Incompressible Flow of Fluid with Free Surface, Physics of Fluids, vol.8, issue.12, pp.12-2182, 1965. ,
DOI : 10.1063/1.1761178
Rapid, stable fluid dynamics for computer graphics, Proceedings of ACM SIG- GRAPH. Num, vol.24, pp.4-49, 1990. ,
Wavelet turbulence for fluid simulation Ray tracing volume densities, Proceedings of ACM SIGGRAPH 2008 Proceedings of ACM SIGGRAPH, pp.165-174, 1984. ,
Particle-based fluid simulation for interactive applica- tions, Proceedings of Eurographics/ACM SIG- GRAPH Symposium on Computer Animation 2003, pp.154-159, 2003. ,
Evolving subgrid turbulence for smoke animation, Eurographics/ ACM SIGGRAPH Symposium on Computer Animation, pp.1-7, 2008. ,
Sph based shallow water simulation, Virtual Reality Interactions and Physical Simulation (VRIPhys), pp.39-46, 2011. ,
An unconditionally stable maccormack method, Journal of Scientific Computing, vol.35, pp.2-3, 2007. ,
Density contrast sph interfaces, Proceedings of Eurographics/ ACM SIGGRAPH Symposium on Computer Animation, pp.211-218, 2008. ,
A vortex particle mathod for smoke, water and explositions, ACM Transactions on Graphics (TOG), vol.24, issue.3, pp.910-914, 2005. ,
Stable fluids, Proceedings of the 26th ACM SIGGRAPH conference, pp.121-128, 1999. ,
A multiscale approach to mesh-based surface tension flows, Proceedings of ACM SIGGRAPH 2010, 2010. ,
Animating sand as a fluid, Proceedings of ACM SIGGRAPH 2005 (2005), pp.965-972 ,
Adaptive sampling and rendering of fluids on the gpu, Volume and Point-Based Graphics Eurographics Association, pp.137-146, 2008. ,
