Surface Reconstruction through Point Set Structuring
Florent Lafarge 1 Pierre Alliez 1
1 GEOMETRICA - Geometric computing
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Saclay - Ile de France
Abstract : We present a method for reconstructing surfaces from point sets. The main novelty lies into a structure-preserving approach where the input point set is first consolidated by structuring and resampling the planar components, before reconstructing the surface from both the consolidated components and the unstructured points. The final surface is obtained through solving a graph-cut problem formulated on the 3D Delaunay triangulation of the structured point set where the tetrahedra are labeled as inside or outside cells. Structuring facilitates the surface reconstruction as the point set is substantially reduced and the points are enriched with structural meaning related to adjacency between primitives. Our approach departs from the common dichotomy between smooth/piecewise-smooth and primitive-based representations by gracefully combining canonical parts from detected primitives and free-form parts of the inferred shape. Our experiments on a variety of inputs illustrate the potential of our approach in terms of robustness, flexibility and efficiency.
Document type :
Reports
Complete list of metadatas
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-00768197
Contributor : Florent Lafarge <>
Submitted on : Friday, December 21, 2012 - 7:28:14 AM
Last modification on : Saturday, January 27, 2018 - 1:31:24 AM
Document(s) archivé(s) le : Friday, March 22, 2013 - 3:45:16 AM
File
RR-8174.pdf
Identifiers
  • HAL Id : hal-00768197, version 1
Collections
Citation
Florent Lafarge, Pierre Alliez. Surface Reconstruction through Point Set Structuring. [Research Report] RR-8174, INRIA. 2012, pp.30. ⟨hal-00768197⟩
Share
Metrics
Record views
6632
Files downloads
770
