A test facility for assessing simulations of jets in cross flow configurations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A test facility featuring jet(s) in cross flow con-figuration is presented. The peculiarity of the rig stems from the presence of an acoustic forcing sys-tem that introduces planar acoustic waves in the cross flow. Microphones, PIV and LDV measure-ments have been conducted in forced and unforced configurations. The experimental database built so far already gives the possibility of assessing in depth the predictive capability of related steady or unsteady simulations.
ETMM9_BRUEL_N0064 (1).pdf (772.34 Ko) Télécharger le fichier
hal-00768340 , version 1 (27-07-2022)
  • HAL Id : hal-00768340 , version 1
Pascal Bruel, Juan-Luis Florenciano, Tarik Kousksou, Thomas Lederlin. A test facility for assessing simulations of jets in cross flow configurations. 9th International ERCOFTAC Symposium on Engineering Turbulence Modelling and Measurements, ERCOFTAC, Jun 2012, Thessaloniki, Greece. ⟨hal-00768340⟩
184 Consultations
17 Téléchargements
