Abstract : It is a trend to publish RDF data on the web, so that users can share information semantically. Then, linking isolated data sets together is highly needed. I would like to reduce the comparison scale by isolating the types of resources to be compared, so that it enhances the accuracy of the linking process. I propose a data linking method for linked data on the web. Such a method can interlink linked data automatically by referring to an ontology alignment between linked data sets. Alignments can provide them entities to compare.
