New interface
Journal articles
MultiFarm: A benchmark for multilingual ontology matching
Abstract : In this paper we present the MultiFarm dataset, which has been designed as a benchmark for multilingual ontology matching. The MultiFarm dataset is composed of a set of ontologies translated in different languages and the corresponding alignments between these ontologies. It is based on the OntoFarm dataset, which has been used successfully for several years in the Ontology Alignment Evaluation Initiative (OAEI). By translating the ontologies of the OntoFarm dataset into eight different languages -Chinese, Czech, Dutch, French, German, Portuguese, Russian, and Spanish- we created a comprehensive set of realistic test cases. Based on these test cases, it is possible to evaluate and compare the performance of matching approaches with a special focus on multilingualism.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00768423
Contributor : Jérôme Euzenat Connect in order to contact the contributor
Submitted on : Friday, December 21, 2012 - 2:17:54 PM
Last modification on : Wednesday, July 6, 2022 - 4:20:47 AM
Links full text
Identifiers
Collections
Citation
Christian Meilicke, Raúl García Castro, Frederico Freitas, Willem Robert van Hage, Elena Montiel-Ponsoda, et al.. MultiFarm: A benchmark for multilingual ontology matching. Journal of Web Semantics, 2012, 15 (3), pp.62-68. ⟨10.1016/j.websem.2012.04.001⟩. ⟨hal-00768423⟩
Share
Metrics
Record views
295
