A Latently Constrained Mixture Model for Audio Source Separation and Localization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a method for audio source separation and localization from binaural recordings. The method combines a new generative probabilistic model with time-frequency masking. We suggest that device-dependent relationships between point-source positions and interaural spectral cues may be learnt in order to constrain a mixture model. This allows to capture subtle separation and localization features embedded in the auditory data. We illustrate our method with data composed of two and three mixed speech signals in the presence of reverberations. Using standard evaluation metrics, we compare our method with a recent binaural-based source separation-localization algorithm.
LVA12_submission_revised.pdf (181.93 Ko) Télécharger le fichier
hal-00768660 , version 1 (22-12-2012)
Antoine Deleforge, Radu Horaud. A Latently Constrained Mixture Model for Audio Source Separation and Localization. 10th International Conference on Latent Variable Analysis and Signal Separation, Mar 2012, Tel Aviv, Israel. pp.372--379, ⟨10.1007/978-3-642-28551-6_46⟩. ⟨hal-00768660⟩
417 Consultations
190 Téléchargements
