Determining a sound-soft polyhedral scatterer by a single far-field measurement, Proceedings of the American Mathematical Society, vol.113, issue.6, pp.1685-1691, 2005. ,
Imaging Schemes for Perfectly Conducting Cracks, SIAM Journal on Applied Mathematics, vol.71, issue.1, pp.68-91, 2011. ,
DOI : 10.1137/100800130
ON THE USE OF THE RECIPROCITY-GAP FUNCTIONAL IN INVERSE SCATTERING FROM PLANAR CRACKS, Mathematical Models and Methods in Applied Sciences, vol.15, issue.10, pp.1553-1574, 2005. ,
DOI : 10.1142/S0218202505000819
URL : https://hal.archives-ouvertes.fr/hal-00743896
Application of the linear sampling method to retrieve cracks with impedance boundary conditions, Inverse Problems in Science and Engineering, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00543901
Fast identification of cracks using higher-order topological sensitivity for 2-D potential problems, Engineering Analysis with Boundary Elements, vol.35, issue.2, pp.223-235, 2011. ,
DOI : 10.1016/j.enganabound.2010.08.007
URL : https://hal.archives-ouvertes.fr/hal-00495407
Crack detection using electrostatic measurements, ESAIM: Mathematical Modelling and Numerical Analysis, vol.35, issue.3, pp.595-605, 2001. ,
DOI : 10.1051/m2an:2001128
A review of selected works on crack identification Geometric methods in inverse problems and PDE control, Math. Appl, vol.137, pp.25-46, 2004. ,
Qualitative Methods in Inverse Scattering Theory, 2006. ,
The linear sampling method for cracks, Inverse Problems, vol.19, issue.2, pp.279-95, 2003. ,
DOI : 10.1088/0266-5611/19/2/303
Inverse acoustic and electromagnetic scattering theory, 1998. ,
Error estimates of the DtN finite element method for the exterior Helmholtz problem, J. Comput. Appl. Math, pp.21-31, 2007. ,
The linear sampling method in inverse obstacle scattering for impedance boundary conditions, Journal of Inverse and Ill-posed Problems, vol.10, issue.2, pp.171-185, 2002. ,
DOI : 10.1515/jiip.2002.10.2.171
Inverse scattering for planar cracks via nonlinear integral equations, Mathematical Methods in the Applied Sciences, vol.1, issue.10, pp.1221-1232, 2008. ,
DOI : 10.1002/mma.970
Reconstruction of an acoustically sound-soft obstacle from one incident field and the far-field pattern, IMA Journal of Applied Mathematics, vol.72, issue.1, pp.96-112, 2007. ,
DOI : 10.1093/imamat/hxl026
The Factorization Method for Inverse Problems, Oxford Lecture in Mathematics and its applications 36, 2008. ,
DOI : 10.1093/acprof:oso/9780199213535.001.0001
A linear sampling method for inverse scattering from an open arc, Inverse Problems, vol.16, issue.1, pp.89-105, 2000. ,
DOI : 10.1088/0266-5611/16/1/308
A hybrid method for two-dimensional crack reconstruction, Inverse Problems, vol.21, issue.2, pp.773-784, 2005. ,
DOI : 10.1088/0266-5611/21/2/020
The factorization method is independent of transmission eigenvalues, Inverse Problems and Imaging, vol.3, issue.1, pp.123-138, 2009. ,
DOI : 10.3934/ipi.2009.3.123
URL : https://hal.archives-ouvertes.fr/hal-00782982
Strongly Elliptic Systems and Boundary Integral Equations, 2000. ,
Acoustic and electromagnetic equations, Applied Matimatical Sciences, 2001. ,
Reconstruction of cracks of different types from far-field measurements, Mathematical Methods in the Applied Sciences, vol.50, issue.8, pp.950-973, 2010. ,
DOI : 10.1088/1742-6596/135/1/012056
The Identification of Thin Dielectric Objects from Far Field or Near Field Scattering Data, SIAM Journal on Applied Mathematics, vol.69, issue.4, pp.1024-1042, 2009. ,
DOI : 10.1137/070711542
