New interface
Conference papers
Revisiting the open boundary problem in computational fluid dynamics
Véronique Martin 1 Eric Blayo 2
2 MOISE - Modelling, Observations, Identification for Environmental Sciences
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : The overall context of this work is the design of e cient open boundary conditions (OBCs) for limited area models of the ocean circulation. In these limited areas, complex systems of equations are solved using a high resolution grid. On the arti cial boundaries, boundary conditions with some available external information, must be prescribed. Such external information is generally available from previous simulations of large scale low resolution models. Ideally, the OBC must evacuate the outgoing information reaching the boundary, and must take into account the incoming part of the external information. In this talk, we propose a reformulation of this problem in which the link with absorbing boundary conditions is highlighted. This formulation allows a complete treatment of the problem in simple cases like the 1D Laplace equation, which illustrates in particular the context in which absorbing conditions may be or not e cient OBCs. Moreover some numerical applications for shallow water systems will be given
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00769113
Contributor : Eric Blayo Connect in order to contact the contributor
Submitted on : Friday, December 28, 2012 - 11:32:10 AM
Last modification on : Tuesday, October 25, 2022 - 4:18:01 PM
Identifiers
  • HAL Id : hal-00769113, version 1
Citation
Véronique Martin, Eric Blayo. Revisiting the open boundary problem in computational fluid dynamics. DD 20 - 20th international conference on Domain Decomposition Methods, Feb 2011, San Diego, United States. ⟨hal-00769113⟩
Share
Metrics
Record views
166
