Diagnosing linklevel anomalies using passive probes, Proceedings of INFOCOM, 2007. ,
Network performance anomaly detection and localization, Proceedings of INFOCOM, 2009. ,
Detecting anomalies using end-to-end path measurements, INFOCOM, 2008. ,
Adaptive diagnosis in distributed systems, IEEE Transactions on Neural Networks, vol.16, issue.4, pp.1088-1109, 2005. ,
Real-time problem determination in distributed systems using active probing, Proceedings of the Network Operations and Management Symposium, 2004. ,
Efficient active probing for fault diagnosis in large scale and noisy networks, Proceedings of IEEE INFOCOM, 2010. ,
Active probing strategies for problem diagnosis in distributed systems, Proceedings of the International Joint Conferences on Artificial Intelligence, 2003. ,
Probabilistic fault diagnosis using adaptive probing In Proceedings of the Distributed systems: operations and management 18th IFIP, 2007. ,
Optimizing Probe Selection for Fault Localization, Proceedings of Distributed Systems Operation and Management, 2001. ,
Robust Monitoring of Link Delays and Faults in IP Networks, IEEE/ACM Transactions on Networking, vol.14, issue.5, pp.1092-1103, 2006. ,
DOI : 10.1109/TNET.2006.882907
Towards efficient large-scale vpn monitoring and diagnosis under operational constraints, Proceedings of INFOCOM 2009 ,
Joint optimization of monitor location and network anomaly detection, Proceedings of IEEE LCN, 2010. ,
Heuristics for joint optimization of monitor location and network anomaly detection, Proceedings of IEEE ICC, 2011. ,
Localization of single network link-level anomalies, Proceedings of IEEE ICCCN, 2012. ,
Improved Approximation Algorithms for the Uncapacitated Facility Location Problem, ACM SIAM Journal on Computing, vol.33, issue.1, pp.1-25, 2004. ,
