Filtering XFD Toward Interoperability (short paper) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes an algorithm for computing the maximal set of XML functional dependencies (XFD) that is guaranteed to hold across a set of local systems, each with its own defined set of XFD. Our method is based on an axiom system that we have proved to be sound and complete. An implementation demonstrates its feasibility.
Fichier non déposé
hal-00771002 , version 1 (07-01-2013)
  • HAL Id : hal-00771002 , version 1
Joshua Amavi, Mirian Halfeld Ferrari. Filtering XFD Toward Interoperability (short paper). 28th Symposium On Applied Computing, SAC 2013, Mar 2013, Coimbra, Portugal. ⟨hal-00771002⟩
657 Consultations
0 Téléchargements
