Conference papers
Non Linear Divisible Loads: There is No Free Lunch
Olivier Beaumont 1, 2 Hubert Larchevêque 1, 2 Loris Marchal 3, 4
1 CEPAGE - Algorithmics for computationally intensive applications over wide scale distributed platforms
Université Sciences et Technologies - Bordeaux 1, Inria Bordeaux - Sud-Ouest, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
3 ROMA - Optimisation des ressources : modèles, algorithmes et ordonnancement
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : Divisible Load Theory (DLT) has received a lot of attention in the past decade. A divisible load is a perfect parallel task, that can be split arbitrarily and executed in parallel on a set of possibly heterogeneous resources. The success of DLT is strongly related to the existence of many optimal resource allocation and scheduling algorithms, what strongly differs from general scheduling theory. Moreover, recently, close relationships have been underlined between DLT, that provides a fruitful theoretical framework for scheduling jobs on heterogeneous platforms, and MapReduce, that provides a simple and efficient programming framework to deploy applications on large scale distributed platforms. The success of both have suggested to extend their framework to non-linear complexity tasks. In this paper, we show that both DLT and MapReduce are better suited to workloads with linear complexity. In particular, we prove that divisible load theory cannot directly be applied to quadratic workloads, such as it has been proposed recently. We precisely state the limits for classical DLT studies and we review and propose solutions based on a careful preparation of the dataset and clever data parti- tioning algorithms. In particular, through simulations, we show the possible impact of this approach on the volume of communications generated by MapReduce, in the context of Matrix Multiplication and Outer Product algorithms.
Complete list of metadata
Cited literature [38 references]  Display  Hide  Download
https://hal.inria.fr/hal-00771640
Contributor : Olivier Beaumont Connect in order to contact the contributor
Submitted on : Wednesday, January 9, 2013 - 10:12:48 AM
Last modification on : Friday, September 30, 2022 - 4:02:40 AM
Long-term archiving on: : Wednesday, April 10, 2013 - 3:49:13 AM
File
nofreelunch.pdf
Identifiers
  • HAL Id : hal-00771640, version 1
Citation
Olivier Beaumont, Hubert Larchevêque, Loris Marchal. Non Linear Divisible Loads: There is No Free Lunch. IPDPS 2013, 27th IEEE International Parallel & Distributed Processing Symposium, IEEE, May 2013, Boston, United States. ⟨hal-00771640⟩
Share
Metrics
Record views
497
Files downloads
206
