Finite-Sample Analysis of Least-Squares Policy Iteration - Archive ouverte HAL Access content directly
Journal Articles Journal of Machine Learning Research Year : 2012
Alessandro Lazaric
Mohammad Ghavamzadeh
  • Function : Author
  • PersonId : 868946
Rémi Munos
  • Function : Author
  • PersonId : 836863
In this paper, we report a performance bound for the widely used least-squares policy iteration (LSPI) algorithm. We first consider the problem of policy evaluation in reinforcement learning, that is, learning the value function of a fixed policy, using the least-squares temporal-difference (LSTD) learning method, and report finite-sample analysis for this algorithm. To do so, we first derive a bound on the performance of the LSTD solution evaluated at the states generated by the Markov chain and used by the algorithm to learn an estimate of the value function. This result is general in the sense that no assumption is made on the existence of a stationary distribution for the Markov chain. We then derive generalization bounds in the case when the Markov chain possesses a stationary distribution and is $\beta$-mixing. Finally, we analyze how the error at each policy evaluation step is propagated through the iterations of a policy iteration method, and derive a performance bound for the LSPI algorithm.
lazaric12a.pdf (270.78 Ko) Télécharger le fichier
Dates and versions
hal-00772060 , version 1 (09-01-2013)
Identifiers
  • HAL Id : hal-00772060 , version 1
Cite
Alessandro Lazaric, Mohammad Ghavamzadeh, Rémi Munos. Finite-Sample Analysis of Least-Squares Policy Iteration. Journal of Machine Learning Research, 2012, 13, pp.3041-3074. ⟨hal-00772060⟩
189 View
190 Download
Share
