Observavility Brunovsky Normal Form: Multi-Output Linear Dynamical Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper gives the sufficient and necessary conditions to guarantee the existence of a linear change of coordinates to transform a multi-output linear dynamical system (modulo a nonlinear term depending on inputs and outputs) in the observability Brunovsky canonical form.
ACC09BBKNV.pdf (86.18 Ko) Télécharger le fichier
hal-00772281 , version 1 (10-01-2013)
  • HAL Id : hal-00772281 , version 1
Driss Boutat, Frédéric Kratz, Jean-Pierre Barbot. Observavility Brunovsky Normal Form: Multi-Output Linear Dynamical Systems. American Control Conference, ACC09, IEEE, Jun 2009, St. Louis, MO, United States. ⟨hal-00772281⟩
283 Consultations
1370 Téléchargements
