Algorithmic specifications in linear logic with subexponentials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The linear logic exponentials !, ? are not canonical: one can add to linear logic other such operators, say !^l, ?^l, which may or may not allow contraction and weakening, and where l is from some pre-ordered set of labels. We shall call these additional operators subexponentials and use them to assign locations to multisets of formulas within a linear logic programming setting. Treating locations as subexponentials greatly increases the algorithmic expressiveness of logic. To illustrate this new expressiveness, we show that focused proof search can be precisely linked to a simple algorithmic specification language that contains while-loops, conditionals, and insertion into and deletion from multisets. We also give some general conditions for when a focused proof step can be executed in constant time. In addition, we propose a new logical connective that allows for the creation of new subexponentials, thereby further augmenting the algorithmic expressiveness of logic.
Fichier non déposé
hal-00772332 , version 1 (10-01-2013)
  • HAL Id : hal-00772332 , version 1
Nigam Vivek, Dale Miller. Algorithmic specifications in linear logic with subexponentials. PPDP09 - ACM SIGPLAN Conference on Principles and Practice of Declarative Programming, Sep 2009, Coimbra, Portugal. ⟨hal-00772332⟩
125 Consultations
0 Téléchargements
