A stronger necessary condition for the multistationarity of chemical reaction networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Sylvain Soliman
Biochemical systems grow bigger and bigger, fed by the new high-throughput data provided by biologists and bred in open repositories of models allowing merging and evolution. Nevertheless, since the available data is still very far from permitting the identification of the increasing number of kinetic parameters of such models, the necessity of structural analyses for describing the dynamics of chemical networks appears stronger every day. Using the structural information, notably from the stoichiometric matrix, of a biochemical reaction system, we state a more strict version of the famous Thomas' necessary condition for multistability. In particular, the obvious cases where Thomas' condition was trivially satisfied, mutual inhibition due to a multimolecular reaction and mutual activation due to a reversible reaction, can now easily be ruled out. This more strict condition shall not be seen as some version of Thomas' circuit functionality for the continuous case but rather as related and complementary to the whole domain of the structural analysis of (bio)chemical reaction systems, as pioneered by Chemical Reaction Network Theory.
Soliman13jmb.pdf (257.11 Ko) Télécharger le fichier
hal-00772438 , version 1 (10-01-2013)
hal-00772438 , version 2 (01-02-2013)
hal-00772438 , version 3 (22-02-2013)
hal-00772438 , version 4 (03-04-2013)
hal-00772438 , version 5 (16-05-2013)
  • HAL Id : hal-00772438 , version 1
Sylvain Soliman. A stronger necessary condition for the multistationarity of chemical reaction networks. 2013. ⟨hal-00772438v1⟩
700 Consultations
646 Téléchargements
