A fixpoint theorem in linear logic, an email posting to the mailing list linear@cs, 1992. ,
Rules of definitional reflection, [1993] Proceedings Eighth Annual IEEE Symposium on Logic in Computer Science, pp.222-232, 1993. ,
DOI : 10.1109/LICS.1993.287585
Cut-elimination for a logic with definitions and induction, Theoretical Computer Science, vol.232, issue.1-2, pp.91-119, 2000. ,
DOI : 10.1016/S0304-3975(99)00171-1
Encoding transition systems in sequent calculus, Theoretical Computer Science, vol.294, issue.3, pp.411-437, 2003. ,
DOI : 10.1016/S0304-3975(01)00168-2
Induction and co-induction in sequent calculus Post-proceedings of TYPES, LNCS, issue.3085, pp.293-308, 2003. ,
A logical framework for reasoning about logical specifications, 2004. ,
Communicating and Mobile Systems : The ?-calculus, 1999. ,
Uniform proofs as a foundation for logic programming, Annals of Pure and Applied Logic, vol.51, issue.1-2, pp.125-157, 1991. ,
DOI : 10.1016/0168-0072(91)90068-W
A framework for defining logics, Journal of the ACM, vol.40, issue.1, pp.143-184, 1993. ,
DOI : 10.1145/138027.138060
Abstract Syntax for Variable Binders: An Overview, Computational Logic -CL 2000, no. 1861 in LNAI, pp.239-253, 2000. ,
DOI : 10.1007/3-540-44957-4_16
Higher-order abstract syntax, Proceedings of the ACM- SIGPLAN Conference on Programming Language Design and Implementation, pp.199-208, 1988. ,
An Overview of ?Prolog, in: Fifth International Logic Programming Conference, pp.810-827, 1988. ,
System Description: Twelf ??? A Meta-Logical Framework for Deductive Systems, 16th Conf. on Automated Deduction (CADE), no. 1632 in LNAI, pp.202-206, 1999. ,
DOI : 10.1007/3-540-48660-7_14
A proof theory for generic judgments, ACM Transactions on Computational Logic, vol.6, issue.4, pp.749-783, 2005. ,
DOI : 10.1145/1094622.1094628
The Bedwyr System for Model Checking over Syntactic Expressions, 21th Conf. on Automated Deduction (CADE), no. 4603 in LNAI, pp.391-397, 2007. ,
DOI : 10.1007/978-3-540-73595-3_28
A Logic for Reasoning about Generic Judgments, Int. Workshop on Logical Frameworks and Meta-Languages: Theory and Practice (LFMTP'06), pp.3-18, 2006. ,
DOI : 10.1016/j.entcs.2007.01.016
Reasoning in Abella about Structural Operational Semantics Specifications, International Workshop on Logical Frameworks and Meta-Languages: Theory and Practice, pp.85-100, 2008. ,
DOI : 10.1016/j.entcs.2008.12.118
Nominal logic, a first order theory of names and binding, Information and Computation, vol.186, issue.2, pp.165-193, 2003. ,
DOI : 10.1016/S0890-5401(03)00138-X
Combining Generic Judgments with Recursive Definitions, 2008 23rd Annual IEEE Symposium on Logic in Computer Science, pp.33-44, 2008. ,
DOI : 10.1109/LICS.2008.33
URL : http://arxiv.org/abs/0802.0865
The Abella Interactive Theorem Prover (System Description), Fourth International Joint Conference on Automated Reasoning, pp.154-161, 2008. ,
DOI : 10.1007/978-3-540-71070-7_13
A Proof Search Specification of the ??-Calculus, 3rd Workshop on the Foundations of Global Ubiquitous Computing, pp.79-101, 2004. ,
DOI : 10.1016/j.entcs.2005.05.006
A formulation of the simple theory of types, The Journal of Symbolic Logic, vol.1, issue.02, pp.56-68, 1940. ,
DOI : 10.2307/2371199
Unification under a mixed prefix, Journal of Symbolic Computation, vol.14, issue.4, pp.321-358, 1992. ,
DOI : 10.1016/0747-7171(92)90011-R
A unification algorithm for typed ??-calculus, Theoretical Computer Science, vol.1, issue.1, pp.27-57, 1975. ,
DOI : 10.1016/0304-3975(75)90011-0
Induction and co-induction in sequent calculus, p.4727, 2009. ,
Cut elimination for a logic with generic judgments and induction, Tech. rep., CoRR, extended version of LFMTP'06 paper Available from http, p.3065, 2008. ,
Intensional interpretations of functionals of finite type I, The Journal of Symbolic Logic, vol.91, issue.02, pp.198-212, 1967. ,
DOI : 10.1007/BF01447860
Reasoning with higher-order abstract syntax in a logical framework, ACM Transactions on Computational Logic, vol.3, issue.1, pp.80-136, 2002. ,
DOI : 10.1145/504077.504080
Proof search specifications of bisimulation and modal logics for the ??-calculus, ACM Transactions on Computational Logic, vol.11, issue.2 ,
DOI : 10.1145/1656242.1656248
A proof theory for generic judgments: an extended abstract, 18th Annual IEEE Symposium of Logic in Computer Science, 2003. Proceedings., pp.118-127, 2003. ,
DOI : 10.1109/LICS.2003.1210051
Nominal logic programming, ACM Transactions on Programming Languages and Systems, vol.30, issue.5, pp.1-47, 2008. ,
DOI : 10.1145/1387673.1387675
URL : http://arxiv.org/abs/cs/0609062
Cut-elimination in logics with definitional reflection, Nonclassical Logics and Information Processing, pp.146-171, 1992. ,
DOI : 10.1007/BFb0031929
A linear approach to the proof-theory of least and greatest fixed points, 2008. ,
On the expressivity of minimal generic quantification International Workshop on Logical Frameworks and Meta-Languages: Theory and Practice, pp.3-19, 2008. ,
A Simpler Proof Theory for Nominal Logic, 8th International Conference on the Foundations of Software Science and Computational Structures (FOSSACS), pp.379-394, 2005. ,
DOI : 10.1007/978-3-540-31982-5_24
Fresh Logic: proof-theory and semantics for FM and nominal techniques, Journal of Applied Logic, vol.5, issue.2, pp.356-387, 2007. ,
DOI : 10.1016/j.jal.2005.10.012
Relating nominal and higher-order abstract syntax specifications, Proceedings of the 12th international ACM SIGPLAN symposium on Principles and practice of declarative programming, PPDP '10, pp.177-186, 2010. ,
DOI : 10.1145/1836089.1836112
URL : http://arxiv.org/abs/1003.5447
Equivariant unification, Journal of Automated Reasoning ,
DOI : 10.1007/s10817-009-9164-3
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.59.2544
Alpha-structural recursion and induction, Journal of the ACM, vol.53, issue.3, pp.459-506, 2006. ,
DOI : 10.1145/1147954.1147961
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.85.518
Nominal Reasoning Techniques in Coq, Electronic Notes in Theoretical Computer Science, vol.174, issue.5, pp.69-77, 2006. ,
DOI : 10.1016/j.entcs.2007.01.028
Nominal Techniques in Isabelle/HOL, Journal of Automated Reasoning, vol.323, issue.1???2, pp.327-356, 2008. ,
DOI : 10.1007/s10817-008-9097-2
Reasoning in a logic with definitions and induction, 1997. ,
A framework for specifying, prototyping, and reasoning about computational systems, 2009. ,
Automated theorem proving in a simple meta-logic for LF, 15th Conf. on Automated Deduction (CADE), pp.286-300, 1998. ,
DOI : 10.1007/BFb0054266
Automating the meta theory of deductive systems, pp.0-146, 2000. ,
