Transfer in Reinforcement Learning: a Framework and a Survey - Archive ouverte HAL Access content directly
Book Sections Year : 2012
Alessandro Lazaric
Transfer in reinforcement learning is a novel research area that focuses on the development of methods to transfer knowledge from a set of source tasks to a target task. Whenever the tasks are \textit{similar}, the transferred knowledge can be used by a learning algorithm to solve the target task and significantly improve its performance (e.g., by reducing the number of samples needed to achieve a nearly optimal performance). In this chapter we provide a formalization of the general transfer problem, we identify the main settings which have been investigated so far, and we review the most important approaches to transfer in reinforcement learning.
transfer.pdf (428.94 Ko) Télécharger le fichier
Dates and versions
hal-00772626 , version 1 (10-01-2013)
Identifiers
Cite
Alessandro Lazaric. Transfer in Reinforcement Learning: a Framework and a Survey. Marco Wiering, Martijn van Otterlo. Reinforcement Learning - State of the art, 12, Springer, pp.143-173, 2012, ⟨10.1007/978-3-642-27645-3_5⟩. ⟨hal-00772626⟩
322 View
4661 Download
Share
