Fault tolerant control for induction motors using sliding mode observers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper a fault tolerant control design based on a sliding mode observer for induction motors is proposed. First, a direct field oriented controller based on backstepping technique is designed in order to steer the flux and speed variables to their desired references and to compensate the load disturbance. Second, a sliding mode observer is designed in order to detect and reconstruct the faults and also to estimate the flux. Then, additional control laws based on the estimates of the faults are designed in order to compensate the faults. Numerical simulations show the effectiveness of the proposed control scheme.
Automatique
FTC_SMO.pdf (217.8 Ko) Télécharger le fichier
hal-00772797 , version 1 (11-01-2013)
  • HAL Id : hal-00772797 , version 1
Nadia Djeghali, Malek Ghanes, Said Djennoune, Jean-Pierre Barbot. Fault tolerant control for induction motors using sliding mode observers. VSS, Jun 2011, Mexico, Mexico. ⟨hal-00772797⟩
353 Consultations
695 Téléchargements
