Other publications
Type-based heap and stack space analysis in Java
Emmanuel Hainry 1 Romain Péchoux 1
1 CARTE - Theoretical adverse computations, and safety
LORIA - FM - Department of Formal Methods , Inria Nancy - Grand Est
Abstract : A type system is introduced for a strict but expressive subset of Java in order to infer resource upper bounds on both the heap-space and the stack-space requirements of typed programs. This type system is inspired by previous works on Implicit Computational Complexity, using tiering and non-interference techniques. The presented methodology has several advantages. First, it provides explicit polynomial upper bounds to the programmer, hence avoiding OutOfMemory and StackOverFlow errors. Second, type checking is decidable in linear time. Last, it has a good expressivity since it analyzes most object oriented features like overload, inheritance, override.
Document type :
Other publications
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-00773141
Contributor : Romain Péchoux Connect in order to contact the contributor
Submitted on : Wednesday, November 27, 2013 - 1:59:42 PM
Last modification on : Saturday, October 16, 2021 - 11:26:05 AM
Long-term archiving on: : Saturday, April 8, 2017 - 2:50:54 AM
File
ObjectIsBeautiful.pdf
Identifiers
  • HAL Id : hal-00773141, version 4
Collections
Citation
Emmanuel Hainry, Romain Péchoux. Type-based heap and stack space analysis in Java. 2013. ⟨hal-00773141v4⟩
Share
Metrics
Record views
422
Files downloads
212
