Cutting down trees with a Markov chainsaw - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2014
We provide simplified proofs for the asymptotic distribution of the number of cuts required to cut down a Galton--Watson tree with critical, finite-variance offspring distribution, conditioned to have total progeny n. Our proof is based on a coupling which yields a precise, non-asymptotic distributional result for the case of uniformly random rooted labeled trees (or, equivalently, Poisson Galton--Watson trees conditioned on their size). Our approach also provides a new, random reversible transformation between Brownian excursion and Brownian bridge.
hal-00773364 , version 1 (13-01-2013)
Louigi Addario-Berry, Nicolas Broutin, Cecilia Holmgren. Cutting down trees with a Markov chainsaw. The Annals of Applied Probability, 2014, 24 (6), pp.2297-2339. ⟨10.1214/13-AAP978⟩. ⟨hal-00773364⟩
Collections
INRIA INRIA2
78 Consultations
0 Téléchargements
