Noise impact on error-free image compression, IEEE Transactions on Medical Imaging, vol.9, issue.2, pp.202-206, 1990. ,
Tsybakov Information transmission with additional noise, IEEE Transactions on Information Theory, vol.8, issue.5, pp.293-304, 1962. ,
DOI : 10.1109/tit.1962.1057738
On optimal quantization of noisy sources, IEEE Transactions on Information Theory, vol.36, issue.6, pp.1450-1452, 1990. ,
A unified approach for encoding clean and noisy sources by means of waveform and autoregressive model vector quantization, IEEE Transactions on Information Theory, vol.34, issue.4, pp.826-834, 1988. ,
Source encoding in the presence of random disturbance, IEEE Transactions on Information Theory, vol.14, issue.1, pp.165-167, 1968. ,
Transmission of noisy information to a noisy receiver with minimum distortion, IEEE Transactions on Information Theory, vol.16, issue.4, pp.406-411, 1970. ,
Wyner-Ziv quantization and transform coding of noisy sources at high rates, Asilomar Conference on Signals, Systems and Computers, pp.2084-2088, 2004. ,
Estimation and noisy source coding, IEEE Transactions on Acoustics, Speech and Signal Processing, vol.38, issue.1, pp.23-34, 1990. ,
DOI : 10.1109/29.45615
Lossy compression of noisy images, IEEE Transactions on Image Processing, vol.7, issue.12, pp.1641-1652, 1998. ,
Image coding using wavelet transform, IEEE Transactions on Image Processing, vol.1, issue.2, pp.205-220, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-01322224
Universal trellis coded quantization, IEEE Transactions on Image Processing, vol.8, issue.12, pp.1677-1687, 1999. ,
DOI : 10.1109/isit.1995.550420
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.49.4607
Embedded image coding using zerotrees of wavelet coefficients, IEEE Transactions on Signal Processing, vol.41, issue.12, pp.3445-3462, 1993. ,
A new, fast, and efficient image codec based on set partitioning in hierarchical trees, IEEE Transactions on Circuits and Systems for Video Technology, vol.6, issue.3, pp.243-250, 1996. ,
High performance scalable image compression with EBCOT, IEEE Transactions on Image Processing, vol.9, issue.7, pp.1158-1170, 2000. ,
Oriented Wavelet Transform for Image Compression and Denoising, IEEE Transactions on Image Processing, vol.15, issue.10, pp.2892-2903, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00504227
De-noising by soft-thresholding, IEEE Transactions on Information Theory, vol.41, issue.3, pp.613-627, 1995. ,
A theory of nonsubtractive dither, IEEE Transactions on Signal Processing, vol.48, issue.2, pp.499-516, 2000. ,
Dither in Digital Audio, Journal of the Audio Engineering Society, vol.35, issue.12, pp.966-975, 1987. ,
Generalized Lagrange Multiplier Method for Solving Problems of Optimum Allocation of Resources, Operations Research, vol.11, issue.3, pp.399-417, 1963. ,
Optimal bit allocation for biorthogonal wavelet coding, Data Compression Conference, pp.387-395, 1996. ,
DOI : 10.1109/dcc.1996.488344
Biorthogonal bases of compactly supported wavelets, Communications on Pure and Applied Mathematics, vol.45, issue.5, pp.485-560, 1992. ,
A Mathematical Theory of Communication, Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
Nonlinear programming, Berkeley Symposium on Mathematical Statistics and Probability, pp.481-492, 1951. ,
Coding theorems for a discrete source with a fidelity criterion, IRE International Convention Record, vol.7, pp.142-163, 1959. ,
Asymptotically efficient quantizing, IEEE Transactions on Information Theory, vol.14, issue.5, pp.676-683, 1968. ,
