Optimal joint decoding/deblurring method for optical images, IEEE International Conference on Image Processing, pp.381-385, 1999. ,
Transmission of noisy information to a noisy receiver with minimum distortion, IEEE Transactions on Information Theory, vol.16, issue.4, pp.406-411, 1970. ,
Imagerie spatiale : des principes d'acquisition au traitement des images optiques pour l, 2008. ,
On-board optical image compression for future high-resolution remote sensing systems, Proc. SPIE Applications of Digital Image Processing, 2000. ,
A Mathematical Theory of Communication, Bell System Technical Journal, vol.27, issue.3, pp.379-423, 1948. ,
Image coding using wavelet transform, IEEE Transactions on Image Processing, vol.1, issue.2, pp.205-220, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-01322224
Rate Distortion Theory: A Mathematical Basis for Data Compression, 1971. ,
Rate-distortion methods for image and video compression, IEEE Signal Processing Magazine, vol.15, issue.6, pp.23-50, 1998. ,
Deconvolution by thresholding in mirror wavelet bases, IEEE Transactions on Image Processing, vol.12, issue.4, pp.446-457, 2003. ,
Shearlet-Based Deconvolution, IEEE Transactions on Image Processing, vol.18, issue.12, pp.2673-2685, 2009. ,
DOI : 10.1109/tip.2009.2029594
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.369.4744
A wavelet tour of signal processing, 2008. ,
The contourlet transform: an efficient directional multiresolution image representation, IEEE Transactions on Image Processing, vol.14, issue.12, pp.2091-2106, 2005. ,
Fast discrete curvelet transforms, Multiscale Model. Simul, vol.5, issue.3, pp.861-899, 2006. ,
ForWaRD: Fourier-Wavelet Regularized Deconvolution for Ill-Conditioned Systems, IEEE Transactions on Signal Processing, vol.52, issue.2, pp.418-433, 2004. ,
Stein block thresholding for wavelet-based image deconvolution, Electronic Journal of Statistics, vol.4, pp.415-435, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00436661
A l1-unified variational framework for image restoration, European Conference on Computer Vision, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00217251
Monte-Carlo SURE: A Black-Box Optimization of Regularization Parameters for General Denoising Algorithms, IEEE Transactions on Image Processing, vol.17, issue.9, pp.1540-1554, 2008. ,
Reconstruction Of Wavelet Coefficients Using Total Variation Minimization, SIAM Journal on Scientific Computing, vol.24, pp.1754-1767, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00712152
Compression artifacts reduction using variational methods: algorithms and experimental study, IEEE International Conference on Acoustics, Speech, and Signal Processing, 2008. ,
DOI : 10.1109/icassp.2008.4517824
Nonlinear Total Variation based noise removal algorithms, Physica D, vol.60, pp.259-268, 1992. ,
Dither Signals and Their Effect on Quantization Noise, IEEE Transactions on Communication Technology, vol.12, issue.4, pp.162-165, 1964. ,
DOI : 10.1109/tcom.1964.1088973
A theory of nonsubtractive dither, IEEE Transactions on Signal Processing, vol.48, issue.2, pp.499-516, 2000. ,
Quantization and Dither: A Theoretical Survey, Journal of the Audio Engineering Society, vol.40, issue.5, pp.355-375, 1992. ,
Image de-blurring and application to SPOT5 THR satellite imaging, IEEE International Geoscience and Remote Sensing Symposium, vol.1, pp.318-320, 2003. ,
Anti-Forensics of Digital Image Compression, IEEE Transactions on Information Forensics and Security, vol.6, issue.3, pp.1050-1065, 2011. ,
Text and picture segmentation by the distribution analysis of wavelet coefficients, IEEE International Conference on Image Processing, pp.790-794, 1998. ,
Biorthogonal bases of compactly supported wavelets, Communications on Pure and Applied Mathematics, vol.45, issue.5, pp.485-560, 1992. ,
