Convex Optimization, 2004. ,
Fast approximate energy minimization via graph cuts, PAMI, vol.23, issue.11, pp.1222-1239, 2001. ,
DOI : 10.1109/iccv.1999.791245
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6806
Approximation algorithms for the metric labelling problem via a new linear programming formulation, SODA, 2001. ,
The parition problem, Mathematical Programming, vol.59, pp.87-115, 1993. ,
Modeling and Applications of Stochastic Processes, Kluwer, 1986. ,
The complexity of multi-terminal cuts, SICOMP, vol.23, issue.4, pp.864-894, 1994. ,
Approximate graph colouring and max-k-cut algorithms based on the theta function, Journal of Combinatorial Optimization, vol.8, issue.3, pp.267-294, 2004. ,
Improved approximation algorithms for maximum cut and satisfiability problems using semidefinite programming, Journal of ACM, vol.42, pp.1115-1145, 1995. ,
A bound on the roof duality gap, 1987. ,
Roof duality, complementation and persistency in quadratic 0-1 optimization, Mathematical Programming, pp.121-155, 1984. ,
Exact optimization for Markov random fields with convex priors, PAMI, vol.25, issue.10, pp.1333-1336, 2003. ,
DOI : 10.1109/tpami.2003.1233908
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.106.8689
Minimum 0-extension of graph metrics, European Journal of Combinatorics, vol.19, pp.71-101, 1998. ,
Second-order cone programming relaxation of nonconvex quadratic optimization problems, 2000. ,
Approximation algorithms for classification problems with pairwise relationships: Metric labeling and Markov random fields, STOC, pp.14-23, 1999. ,
Convergent tree-reweighted message passing for energy minimization, PAMI, vol.28, issue.10, pp.1568-1583, 2006. ,
MRF optimization via dual decomposition: Messagepassing revisited, ICCV, 2007. ,
DOI : 10.1109/iccv.2007.4408890
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.150.3345
The partial constraint satisfaction problem: Facets and lifting theorems, Operations Research Letters, vol.23, pp.3-589, 1998. ,
Efficiently solving convex relaxations for MAP estimation, ICML, 2008. ,
DOI : 10.1145/1390156.1390242
Solving Markov random fields using second order cone programming relaxations, CVPR, volume I, pp.1045-1052, 2006. ,
DOI : 10.1109/cvpr.2006.283
An analysis of convex relaxations for MAP estimation, NIPS, pp.1041-1048, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00773608
Global optimization with polynomials and the problem of moments, SIAM Journal of Optimization, vol.11, pp.796-817, 2001. ,
A new second-order cone programming relaxation for max-cut problems, Journal of Operations Research of Japan, vol.43, pp.164-177, 2003. ,
Solving large scale binary quadratic problems: Spectral methods vs. semidefinite programming, CVPR, pp.1-8, 2007. ,
DOI : 10.1109/cvpr.2007.383202
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.124.2774
Quadratic programming relaxations for metric labelling and Markov random field MAP estimation, ICML, 2006. ,
Message-passing for graph-structured linear programs: Proximal projections, convergence and rounding schemes, ICML, 2008. ,
Subgraph matching with semidefinite programming, IWCIA, 2003. ,
Transforming an arbitrary minsum problem into a binary one, 2006. ,
Sintaksicheskiy analiz dvumernykh zritelnikh singnalov v usloviyakh pomekh (syntactic analysis of two-dimensional visual signals in noisy conditions), Kibernetika, vol.4, pp.113-130, 1976. ,
Some solvable subclass of structural recognition problems, Czech Pattern Recognition Workshop, 2000. ,
Solution to structural recognition (MAX,+)-problems by their equivalent transformations. Part 1, Control Systems and Computers, vol.1, pp.3-15, 2007. ,
Solution to structural recognition (MAX,+)-problems by their equivalent transformations, Control Systems and Computers, vol.2, pp.3-18, 2007. ,
A comparative study of energy minimization methods for markov random fields, ECCV, pages II, pp.16-29, 2006. ,
Solving Markov random fields using semidefinite programming, AISTATS, 2003. ,
Graphical models, exponential families, and variational inference, 2003. ,
DOI : 10.1561/2200000001
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.192.2462
Treewidth-based conditions for exactness of the Sherali-Adams and Lasserre relaxations, 2004. ,
MAP estimation via agreement on trees: Message passing and linear programming, IEEE Trans. on Information Theory, issue.11, pp.513697-3717, 2005. ,
A linear programming approach to max-sum problem: A review, 2007. ,
Understanding belief propagation and its generalizations, 2001. ,
