A Subexponential Algorithm for the Discrete Logarithm Problem with Applications to Cryptography, Proceedings of the 20th Annual Symposium on Foundations of Computer Science, SFCS 1979, pp.55-60, 1979. ,
The Function Field Sieve, ANTS 1994, pp.108-121, 1994. ,
A Subexponential Algorithm for Discrete Logarithms over the Rational Subgroup of the Jacobians of Large Genus Hyperelliptic Curves over Finite Fields, ANTS 1994, pp.28-40, 1994. ,
Function Field Sieve Method for Discrete Logarithms over Finite Fields, Inform. and Comput, vol.151, issue.12, pp.5-16, 1999. ,
Étude des Systèmes Algébriques Surdéterminés. Applications aux codes Correcteurs et à la Cryptographie, 2004. ,
Complexity of Gröbner Basis Computation for Semi-Regular Overdetermined Sequences over F2 with Solutions in F2, Technical Report, vol.5049, 2003. ,
Asymptotic Expansion of the Degree of Regularity for Semi-Regular Systems of Equations, The Effective Methods in Algebraic Geometry Conference, pp.1-14, 2005. ,
Hybrid Approach for Solving Multivariate Systems over Finite Fields, Journal of Math. Cryptology, vol.3, issue.3, pp.177-197, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01148127
Cryptanalysis of HFE, multi-HFE and Variants for Odd and Even Characteristic, Des. Codes Cryptography, pp.1-46, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00776072
Ein Algorithmus zum Auffinden der Basiselemente des Restklassenringes nach einem nulldimensionalen Polynomideal, 1965. ,
Handbook of Elliptic and Hyperelliptic Curve Cryptography . Discrete Mathematics and its Applications, 2005. ,
Fast Evaluation of Logarithms in Fields of Characteristic Two, IEEE Transactions on Information Theory, vol.30, issue.4, pp.587-593, 1984. ,
On the Discrete Logarithm Problem in Elliptic Curves, Compositio Mathematica, vol.147, pp.75-104, 2011. ,
On the Discrete Logarithm Problem in Elliptic Curves II, 2011. ,
A General Framework for Subexponential Discrete Logarithm Algorithms, Acta Arith, vol.102, issue.1, pp.83-103, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00512717
A New Efficient Algorithm for Computing Gröbner Basis (F4), Journal of Pure and Applied Algebra, vol.139, issue.1-3, pp.61-88, 1999. ,
A New Efficient Algorithm for Computing Gröbner Bases without Reduction to Zero (F5), Proceedings of the 2002 International Symposium on Symbolic and Algebraic Computation, pp.75-83, 2002. ,
Algebraic Cryptanalysis of Hidden Field Equation (HFE) Cryptosystems Using Gröbner Bases, CRYPTO 2003, pp.44-60, 2003. ,
Algebraic Cryptanalysis of McEliece Variants with Compact Keys, EUROCRYPT 2010, pp.279-298, 2010. ,
FGb: A Library for Computing Gröbner Bases, ICMS 2010, pp.84-87, 2010. ,
Cryptanalysis of MinRank, CRYPTO 2008, pp.280-296, 2008. ,
Computing Loci of Rank Defects of Linear Matrices using Gröbner Bases and Applications to Cryptology, ISSAC 2010: Proceedings of the 2010 International Symposium on Symbolic and Algebraic Computation, pp.257-264, 2010. ,
Gröbner Bases of Bihomogeneous Ideals Generated by Polynomials of Bidegree (1,1): Algorithms and Complexity, Journal of Symbolic Computation, vol.46, issue.4, pp.406-437, 2011. ,
Solving Systems of Polynomial Equations with Symmetries using SAGBI-Gröbner bases, ISSAC 2009: Proceedings of the 2009 International Symposium on Symbolic and Algebraic Computation, pp.151-158, 2009. ,
A Double Large Prime Variation for Small Genus Hyperelliptic Index Calculus, Math. Comp, vol.76, issue.257, pp.475-492, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00000897
An Algorithm for Solving the Discrete Log Problem on Hyperelliptic Curves, EUROCRYPT 2000, pp.19-34, 2000. ,
URL : https://hal.archives-ouvertes.fr/inria-00512401
Index Calculus for Abelian Varieties of Small Simension and the Elliptic Curve Discrete Logarithm Problem, J. Symb. Comput, vol.44, issue.12, pp.1690-1702, 2009. ,
Inverting HFE Is Quasipolynomial, CRYPTO 2006, pp.345-356, 2006. ,
The Function Field Sieve in the Medium Prime Case, EUROCRYPT 2006, pp.254-270, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00456191
Cryptanalysis of the HFE Public Key Cryptosystem by Relinearization, CRYPTO 1999, pp.19-30, 1999. ,
Elliptic Curve Cryptosystems, Mathematics of Computation, vol.48, pp.203-209, 1987. ,
Gröbner-Bases, Gaussian Elimination and Resolution of Systems of Algebraic Equations, EUROCAL 1983, pp.146-156, 1983. ,
The Algebraic Theory of Modular Systems, Cambridge Mathematical Library, vol.xxxi, 1916. ,
Some Properties of Enumeration in the Theory of Modular Systems, Proc. London Math. Soc. 26, pp.531-555, 1927. ,
Use of Elliptic Curves in Cryptography, CRYPTO 1985, pp.417-426, 1986. ,
Hidden Fields Equations (HFE) and Isomorphisms of Polynomials (IP): Two New Families of Asymmetric Algorithms, EUROCRYPT 1996, pp.33-48, 1996. ,
Solving Degenerate Sparse Polynomial Systems Faster, J. Symbolic Computation, vol.28, pp.155-186, 1999. ,
Summation Polynomials and the Discrete Logarithm Problem on Elliptic Curves, 2004. ,
