Abstract : Formal systems that describe computations over syntactic structures occur frequently in computer science. Logic programming provides a natural framework for encoding and animating such systems. However, these systems often embody variable binding, a notion that must be treated carefully at a computational level. This book aims to show that a programming language based on a simply typed version of higher-order logic provides an elegant and declarative means for realizing such a treatment. Three broad topics are covered in pursuit of this goal. First, a proof-theoretic framework that supports a general view of logic programming is identified. Second, an actual language called λProlog is developed by applying this view to a higher-order logic. Finally, a methodology for computing with specifications is exposed by showing how several computations over formal objects such as logical formulas, functional programs, λ-terms, and π-calculus expressions can be encoded in λProlog.
