Improved bounds for the CF algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2012
Elias Tsigaridas
We consider the problem of isolating the real roots of a square-free polynomial with integer coefficients using the classic variant of the continued fraction algorithm (CF), introduced by Akritas. %% We compute a lower bound on the positive real roots of univariate polynomials using exponential search. This allows us to derive a worst case bound of $\sOB( d^4\tau^2)$ for isolating the real roots of a polynomial with integer coefficients using the {\em classic variant of CF}, where $d$ is the degree of the polynomial and $\tau$ the maximum bitsize of its coefficients. This improves the previous bound of Sharma by a factor of $d^3$ and matches the bound derived by Mehlhorn and Ray for another variant of CF which is combined with subdivision; it also matches the worst case bound of the classical subdivision-based solvers \func{sturm}, \func{descartes}, and \func{bernstein}.
et-improve-bd-cf.pdf (246.65 Ko) Télécharger le fichier
hal-00776230 , version 1 (15-01-2013)
  • HAL Id : hal-00776230 , version 1
Elias Tsigaridas. Improved bounds for the CF algorithm. Theoretical Computer Science, 2012, pp.1-12. ⟨hal-00776230⟩
90 Consultations
162 Téléchargements
