Statistical Fault Detection and Isolation for Linear Time-Varying Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes a statistical approach to fault detection and isolation for linear time-varying (LTV) systems subject to parametric additive faults. The proposed approach combines a GLR test with a recursive filter that cancels out the dynamics of the monitored faults effects. To our knowledge, the proposed recursive filter is new for the considered faults with time-varying profiles. The resulting algorithm handles fault diagnosis with weaker assumptions than usual, in particular on the number of sensors and on the stability of the monitored system.
Automatique
hal-00776898 , version 1 (16-01-2013)
Qinghua Zhang, Michèle Basseville. Statistical Fault Detection and Isolation for Linear Time-Varying Systems. SYSID - 16th IFAC Symposium on System Identification, Jul 2012, Brussels, Belgium. pp.625-630, ⟨10.3182/20120711-3-BE-2027.00145⟩. ⟨hal-00776898⟩
147 Consultations
0 Téléchargements
