A multiscale method for highly oscillatory ordinary differential equations with resonance, Mathematics of Computation, vol.78, issue.266, pp.929-956, 2009. ,
DOI : 10.1090/S0025-5718-08-02139-X
Young Measure Approach to Computing Slowly Advancing Fast Oscillations, Multiscale Modeling & Simulation, vol.6, issue.4, pp.1085-1097, 2000. ,
DOI : 10.1137/070687219
Composition Methods for Differential Equations with Processing, SIAM Journal on Scientific Computing, vol.27, issue.6, pp.1817-1843, 2006. ,
DOI : 10.1137/030601223
Splitting and composition methods in the numerical integration of differential equations, Bol. Soc. Esp. Mat. Apl, pp.45-87, 2008. ,
Half-Explicit Runge???Kutta Methods for Differential-Algebraic Systems of Index 2, SIAM Journal on Numerical Analysis, vol.30, issue.2, pp.538-552, 1993. ,
DOI : 10.1137/0730025
Approximate compositions of a near identity map by multi-revolution Runge-Kutta methods, Numerische Mathematik, vol.97, issue.4, pp.97-635, 2004. ,
DOI : 10.1007/s00211-004-0518-9
On explicit multi-revolution Runge???Kutta schemes, Advances in Computational Mathematics, vol.4, issue.1-3, pp.105-120, 2007. ,
DOI : 10.1007/s10444-004-7209-z
Instabilities and inaccuracies in the integration of highly-oscillatory problems A stroboscopic numerical method for highly oscillatory problems, submitted, maripaz2 [11] M.P. Calvo, J.M. Sanz-Serna, Heterogeneous Multiscale Methods for mechanical systems with vibrations, pp.31-1653, 2009. ,
Error Growth in the Numerical Integration of Periodic Orbits, with Application to Hamiltonian and Reversible Systems, SIAM Journal on Numerical Analysis, vol.34, issue.4, pp.34-1391, 1997. ,
DOI : 10.1137/S0036142995281152
Error growth in the numerical integration of periodic orbits by multistep methods, with application to reversible systems Higher-order averaging, formal series and numerical integration I: B-series, Found, IMA J. Numer . Anal. Comput. Math, vol.18, issue.10, pp.2-57, 1998. ,
The heterogeneous multiscale methods, Comm. Math. Sci, vol.1, pp.87-132, 2003. ,
Vanden-Eijnden, Heterogeneous multiscale methods: A review, Commun. Comput. Phys, vol.2, pp.367-450, 2007. ,
Heterogeneous multiscale methods for stiff ordinary differential equations, Mathematics of Computation, vol.74, issue.252, pp.1707-1742, 2005. ,
DOI : 10.1090/S0025-5718-05-01745-X
Automatic integration of Euler-Lagrange equations with constraints, Journal of Computational and Applied Mathematics, vol.12, issue.13, pp.12-77, 1985. ,
DOI : 10.1016/0377-0427(85)90008-1
The numerical solution of differential-algebraic systems by Runge-Kutta methods Geometric Numerical Integration Equation-free, coarse-grained multiscale computation: enabling macroscopic simulators to perform system-level analysis, Lecture Notes in Math. Commun. Math. Sci, vol.1409, issue.1, pp.715-762, 1989. ,
Murua, Formal series and numerical integrators, Part I: Systems of ODEs and symplectic integrators, Appl. Numer. Math, vol.29, pp.221-251, 1999. ,
An Efficient Numerical Method for Highly Oscillatory Ordinary Differential Equations, SIAM Journal on Numerical Analysis, vol.18, issue.3, pp.0-27, 1981. ,
DOI : 10.1137/0718030
Numerical solution of highly oscillatory ordinary differential equations, Acta Numerica, vol.14, issue.2, pp.437-484, 1997. ,
DOI : 10.1007/BF01600630
Averaging Methods in Nonlinear Dynamical SystemsSerna, Modulated Fourier expansions and heterogeneous multiscale methods, IMA J. Numer. Anal, pp.29-595, 2007. ,
Multiple Time Scale Numerical Methods for the Inverted Pendulum Problem, Multiscale Methods in Science and Engineering, pp.32-241, 1994. ,
DOI : 10.1007/3-540-26444-2_13
Nonintrusive and Structure Preserving Multiscale Integration of Stiff ODEs, SDEs, and Hamiltonian Systems with Hidden Slow Dynamics via Flow Averaging, Symplectic correctors Integration Algorithms and Classical Mechanics , Fields Institute Communications 10, pp.1269-1324, 1996. ,
DOI : 10.1137/090771648
