An algebraic theory of order - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2009
Philippe Chartier
  • Fonction : Auteur
  • PersonId : 833467
Ander Murua
  • Fonction : Auteur
  • PersonId : 902264
In this paper, we present an abstract framework which describes algebraically the derivation of order conditions independently of the nature of differential equations considered or the type of integrators used to solve them. Our structure includes a Hopf algebra of functions, whose properties are used to answer several questions of prime interest in numerical analysis. In particular, we show that, under some mild assumptions, there exist integrators of arbitrarily high orders for arbitrary (modified) vector fields.
chartier-murua-2008.pdf (241.13 Ko) Télécharger le fichier
hal-00777190 , version 1 (17-01-2013)
Philippe Chartier, Ander Murua. An algebraic theory of order. ESAIM: Mathematical Modelling and Numerical Analysis, 2009, 43 (4), pp.607-630. ⟨10.1051/m2an/2009029⟩. ⟨hal-00777190⟩
245 Consultations
81 Téléchargements
