Proofs of numerical programs when the compiler optimizes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Innovations in Systems and Software Engineering Année : 2011
On certain recently developed architectures, a numerical program may give different answers depending on the execution hardware and the compilation. Our goal is to formally prove properties about numerical programs that are true for multiple architectures and compilers.We propose an approach that states the rounding error of each floatingpoint computation whatever the environment and the compiler choices. This approach is implemented in the Frama-C platform for static analysis of C code. Small case studies using this approach are entirely and automatically proved.
ISSE.pdf (584.47 Ko) Télécharger le fichier
hal-00777639 , version 1 (21-02-2013)
  • HAL Id : hal-00777639 , version 1
Sylvie Boldo, Thi Minh Tuyen Nguyen. Proofs of numerical programs when the compiler optimizes. Innovations in Systems and Software Engineering, 2011, 7, pp.151-160. ⟨hal-00777639⟩
164 Consultations
533 Téléchargements
