Efficient Arithmetic in Successive Algebraic Extension Fields Using Symmetries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics in Computer Science Année : 2012
In this article, we present new results for efficient arithmetic operations in a number field K represented by successive extensions. These results are based on multi-modular and evaluation-interpolation techniques. We show how to use intrinsic symmetries in order to increase the efficiency of these techniques. Applications to splitting fields of univariate polynomials are presented.
mcs-main.pdf (411.93 Ko) Télécharger le fichier
hal-00777860 , version 1 (18-01-2013)
hal-00777860 , version 2 (20-01-2013)
Sébastien Orange, Guénaël Renault, Kazuhiro Yokoyama. Efficient Arithmetic in Successive Algebraic Extension Fields Using Symmetries. Mathematics in Computer Science, 2012, 6 (3), pp.217-233. ⟨10.1007/s11786-012-0112-y⟩. ⟨hal-00777860v1⟩
179 Consultations
358 Téléchargements
