Stochastic Search for Global Neighbors Selection in Collaborative Filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Neighborhood based collaborative filtering is a popular ap- proach in recommendation systems. In this paper we propose to apply evolutionary computation to reduce the size of the model used for the recommendation. We formulate the prob- lem of constructing the set of neighbors as an optimization problem that we tackle by stochastic local search. The results we present show that our approach produces a set of global neighbors made up of less than 16% of the entire set of users, thus decreases the size of the model by 84%. Furthermore, this reduction leads to a slight increase of the accuracy of a state of the art clustering based approach, without impacting the coverage.
Fichier non déposé
hal-00778497 , version 1 (20-01-2013)
Amine Boumaza, Armelle Brun. Stochastic Search for Global Neighbors Selection in Collaborative Filtering. SAC - 27th Annual ACM Symposium on Applied Computing - 2012, Mar 2012, Riva del Garda, Italy. pp.232-237, ⟨10.1145/2245276.2245322⟩. ⟨hal-00778497⟩
138 Consultations
0 Téléchargements
