Vision-based guidance and control of a hovering vehicle in unknown, gps-denied environments, IEEE International Conference on Robotics and Automation, 2009. ,
Vincze Fast Ego-motion Estimation with Multi-rate Fusion of Inertial and Vision, The International Journal of Robotics Research, vol.26, pp.577-589, 2007. ,
Vision Based MAV Navigation in Unknown and Unstructured Environments, IEEE International Conference on Robotics and Automation, 2010. ,
Building a Robust Implementation of Bearing-only Inertial SLAM for a UAV, JFR, vol.24, pp.113-143, 2007. ,
An Introduction to Inertial and Visual Sensing, International Journal of Robotics Research, vol.26, pp.519-535, 2007. ,
Editorial: Special Issue: 2nd Workshop on Integration of Vision and Inertial Sensors, The International Journal of Robotics Research, vol.26, issue.6, 2007. ,
Simultaneous Motion and Structure Estimation by Fusion of Inertial and Vision Data, The International Journal of Robotics Research, vol.26, pp.591-605, 2007. ,
Classical Mechanics, 1980. ,
Real-time implementation of airborne inertial-SLAM, Robotics and Autonomous Systems, pp.55-62, 2007. ,
Relative pose calibration between visual and inertial sensors A simple learning strategy for high-speed quadrocopter multi-flips, International Journal of IEEE International Conference on Robotics and Automation, 2010. ,
State Estimation Based on the Concept of Continuous Symmetry and Observability Analysis: the Case of Calibration, IEEE Transactions on Robotics, vol.27, issue.2, pp.239-255, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00578795
Closed-Form Solution for Attitude and Speed Determination by Fusing Monocular Vision and Inertial Sensor Measurements, to be presented at the International Conference on Robotics and Automation A. Martinelli, Vision and IMU Data Fusion: Closed-Form Solutions for Attitude, Speed, Absolute Scale and Bias Determination, 2011. ,
A toolbox for easy calibrating omnidirectional cameras, IEEE International Conference on Inteligent Robots and Systems, 2006. ,
Fusing low-cost image and inertial sensors for passive navigation, Journal of the Institute of Navigation, vol.54, issue.1, 2007. ,
