Unconstraint global polynomial optimization via Gradient Ideal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Marta Abril Bucero
  • Fonction : Auteur
  • PersonId : 935724
Bernard Mourrain
Philippe Trébuchet
  • Fonction : Auteur
  • PersonId : 833470
In this paper, we describe a new method to compute the minimum of a real polynomial function and the ideal defining the points which minimize this polynomial function, assuming that the minimizer ideal is zero-dimensional. Our method is a generalization of Lasserre relaxation method and stops in a finite number of steps. The proposed algorithm combines Border Basis, Moment Matrices and Semidefinite Programming. In the case where the minimum is reached at a finite number of points, it provides a border basis of the minimizer ideal.
optimization1.pdf (279.91 Ko) Télécharger le fichier
hal-00779666 , version 1 (22-01-2013)
hal-00779666 , version 2 (21-02-2013)
hal-00779666 , version 3 (21-03-2013)
Marta Abril Bucero, Bernard Mourrain, Philippe Trébuchet. Unconstraint global polynomial optimization via Gradient Ideal. 2013. ⟨hal-00779666v3⟩
454 Consultations
298 Téléchargements
