Journal articles
SMA---The Smyle Modeling Approach
Abstract : This paper introduces the model-based software development lifecycle model SMA--the Smyle Modeling Approach--which is centered around Smyle. Smyle is a dedicated learning procedure to support engineers to interactively obtain design models from requirements, characterized as either being desired (positive) or unwanted (negative) system behavior. Within SMA, the learning approach is complemented by so-called scenario patterns where the engineer can specify clearly desired or unwanted behavior. This way, user interaction is reduced to the interesting scenarios limiting the design effort considerably. In SMA, the learning phase is further complemented by an effective analysis phase that allows for detecting design flaws at an early design stage. Using learning techniques allows us to gradually develop and refine requirements, naturally supporting evolving requirements, and allows for a rather inexpensive redesign in case anomalous system behavior is detected during analysis, testing, or maintenance. This paper describes the approach and reports on first practical experiences.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-00779913
Contributor : Stefan Haar Connect in order to contact the contributor
Submitted on : Tuesday, January 22, 2013 - 5:03:19 PM
Last modification on : Thursday, January 20, 2022 - 4:20:46 PM
Identifiers
  • HAL Id : hal-00779913, version 1
Citation
Benedikt Bollig, Joost-Pieter Katoen, Carsten Kern, Martin Leucker. SMA---The Smyle Modeling Approach. Computing and Informatics, Slovak University Press, Bratislava, 2010, 29 (1), pp.45-72. ⟨hal-00779913⟩
Share
Metrics
Record views
133
